RE: Beginner prop help
you might be able to attach a water cooling plate on the fins of the esc to get temps down or even remove the plate and install the cooling plate in its place but wow thats hot. have you adjusted your prop up some ? or even look at detounging / bending tips a bit to take some load off it.</p>
