They are full contact seals. He didn't say if he removed the inside seal which is the wrong thing to do with older engines. A lot of engine manufacturers kept the front of the crankcase too short for adequate sealing so they went with a sealed bearing.
ORIGINAL: Hobbsy
Those rubber shields are not the seals, the real seal is the fit between the crankshaft and the crankcase.
