RCU Forums - View Single Post - How to trim without subtrim
Old 06-21-2012 | 07:42 PM
Stixoz
Default RE: How to trim without subtrim
ORIGINAL: Charlie P.
If you are needing to add a lot of trim elevator try lowering both ailerons a tiny bit (a few mm at a time - two turns of the clevis). The bad news is that adding very much will make the model throttle sensitive (like a flat wing).
Cheers for that charlie, i will give that a go!
Stix
