RE: IR battle question: Solved.
hmm that is a very good question. The way I understand it the Mako, talks the Tamiya language BUT and here is the big one the Mako is made to work with the RX18 as a base. <div>The Elmod being a full set up that doesn't need the base it would make you think that there would be an issue. </div><div>
</div><div>If you want I can give the size measurements of the Mako board. As it stands I am not an El Mod person so I can't answer your question.
<div>
</div></div>
