Hmm I wondering if it be better to use a hotter plug instead of using10%? Im thinking 10% may berough on the engine! what do you think?
ORIGINAL: NewRageRC
The transmission isn't sealed, you'll just want to make sure the gears are greased. You're running 20% nitro, you want to see what the oil %age is. The more oil the hotter its going to need to be to burn and the moresusceptibleit's going to be to fouling plugs. I think 10% oil is about what you want.
