RE: Flaps going in opposite direction.
Problem solved, I had one servo on each flap, I went into the tx and try to reverse but I kept on having the same issue and so I simply add a servo signal reverse circuit and the problem no longer exist, both flaps going in the same direction as I wanted it to do, thanks guys.
