RE: SIG RASCAL 40
It's just two flat strips of aluminum. You could make it easily yourself. Four holes drilled in each strip. The hole at each end is for screws to attach the metal strip to the wood beam. The two center holes are for attaching motor to strip. Attach aluminum strips to motor first, then place motor on wood beams and screw it down.
