RCU Forums - View Single Post - How to trim without subtrim
Old 06-24-2012 | 05:24 PM
  #39
Charlie P.'s Avatar
Charlie P.
Default RE: How to trim without subtrim
ORIGINAL: Bozarth
ORIGINAL: Stixoz
I have checked and re-checked the CG and it is right....
Stix
Who cares where it measures (as long as you are close). How does it fly? Sounds nose heavy. Saying the cg is right because the plans say so is like saying your needle valve is set correctly because the instructions say so. Put it where it needs to be.
Kurt
Iagree. The C.Gfrom the plans or ARFmanual are what worked best (presumably) for the designer, or at least where he thought it should be placed initially. Your equipment installation is likely different. But it is a place to start and shound be placed there initially. The only way to judge best C.G.is in flight characteristics. No sense spending a lot of time static balancing a model - get close and get airborne. Unless your tank is at the C.G point it changes in flight, anyway. Even if the tank is there it changes from uplines and downlines as the fuel sloshes.
Us the time you save to laterally balance the model. It will make your loops more solid.
