RCU Forums - View Single Post - Submarine WTC build
Old 06-25-2012 | 02:49 PM
Rogue Sub's Avatar
Rogue Sub
Default RE: Submarine WTC build
Dave
You misunderstand. I have seen your boat. I know they run just fine. I know that you pack more function into your boats then 90% of the modelers out there. I am also aware that you do it at half the cost of most people.I dont doubt your seals (yes they have worked for years). I dont doubt the casings that you use (I have seen you make them work for yourself). Kudos to you and the DIY. You may have missed it but I fully support the DIY hobbyist out there.
The fact that I made one correction to an incorrect statement without a personal attack on your design or self is what is key here. I made a correction to information concerning REAL submarines, which I feel I am fully qualified to make. Mater of fact I wear the dolphins to prove that statement.
You could benefit from letting out some bilge water yourself.
I tell you to spell check because it makes your posts easier to read for the forum users and helps in creating the presence of validity in your statements. NOT because I think your an idiot. The suggestion is for everyones benefit.
And now back to the show.
