[quote]ORIGINAL: Hossfly
Now I would like much if the FF folks would explain the
Discus Launch for
Hand Launch Gliders. I have requested both FF folks of AMA and FM to do so. No Results, other than not interested.
NEVER GIVE UP A CHANCE TO TAKE A JAB AT THE AMA, but if you really need to know, there is always Google.
Discus Launch Glider
From Wikipedia, the free encyclopedia
A Discus Launch Glider (DLG) is a radio controlled model sailplane launched using a 'discus launch' in which the glider is held by a wingtip and rotated around the flyer by hand before release. Using this method of launching the average flier can achieve launch heights of greater than 140 feet (43 m), with the better throwers exceeding 200-foot (61 m) high launches.
The discus method of hand launching has now in effect replaced the older 'javelin style' launch, where a hand launched model glider would be launched over-arm, like a javelin would be thrown. The discus launch is far easier, more efficient and less physically demanding than the javelin launch.
Although some DLG designs utilise a traditional built-up construction using balsa wood and covering film, most DLG models are generally now constructed from composite materials, in the form of Kevlar, carbon fibre and glass fibre. Fuselages are moulded in Kevlar/carbon and epoxy, with wings either moulded as a hollow composite shell, or vacuum bagged over a wire-cut foam core.
Most DLG models use aileron, rudder and elevator control, with the ailerons also being used as camber changing flaps for different modes of flight and also as airbrakes for landing. A modern DLG model weighs approximately 9 or 10 ounces (255-283 grams) and has sophisticated aerodynamics. Many pilots use computer radio transmitters with full mixing and flight mode capabilities in order to optimise performance and set up the models for flight as near perfectly as possible.
DLG models are used for both general fun/sport flying and also for contest flying.
