ORIGINAL: royalstar05
Thanks for the help what about hot glue do you use this also
Yes, I have used hot glue with foam. Regular hot glue may be hot enough to melt foam, so use it with care. Also, the working time of hot glue is very short, so you have only a couple of seconds to position whatever it is you are gluing.
- Jeff
