RE: Value Hobby .60 size Ugly Stik
Got the fuse glued together. Had to whittle the joining pegs to make them fit the taper of the fuse, but it all lined up square in the end. Didn't use the suggested servo mounting method. The servos were going to hit the sides of the hatch hole. Ended up just cutting holes in the aileron servo hatches and adding wood for the screws. Too much trouble to fab up a servo mount that I liked. Turned the motor 45deg to get the GMS, semi-tuned muffler to clear the fuse and wing. Also makes it look racy!! I can tell people that I did it to lower the drag. Not a lot of wood in the fuse to glue in the vertical stab, but I will try it without adding braces. Seems fairly strong.
