RE: Value Hobby .60 size Ugly Stik
Too late for fuse joining pics. I'll try to get some of the final assy. The fuse half has a bulkhead right at the forward edge of the white area. Each bulkhead has a square hole in all four corners. You have to whittle four square pegs to allow the two tapred halves of the fuse to match up when put together. I glued the pegs in one half to secure them. Then I put glue on the other half and pushed them together and taped them to hold it all square. The bulkheads are laser cut so they line up well. Even the pushrod tubes lined up OK. The joint is barely visible since it is at the edge of the white. ___________
l__l l__l
l l
l O O l
l__ _ _l
l__l_____l__l
