RCU Forums - View Single Post - Pine vs Basswood
Old 06-27-2012 | 07:13 PM
cfircav8r's Avatar
cfircav8r
Default RE: Pine vs Basswood
If you want the skinny on wood strength check the homebuilt airplane sites. They have all the info you will ever need about strength and weight. Sitka spruce has long been the choice for F/S aircraft spars, however Douglas Fir is being substituted more frequently. It is heavier, but stronger, so you just make it a little smaller dimension and end up with about the same strength and weight.
