RE: Tesax RC Drastik 120
Good review.
I've noted the Drastick and have wondered how it compares to the Ultra Stick Lite and your offering confirms that it might be more comparable to the original Ultra Stick 120 that weighed about 2.5 lbs more than the USL.
But.... that conclusion might be unfair. If it were given a 1.20 engine, it actually might come in somewhere between the weight of the Ultra Stick Lite and the original Ultra Stick 120?
Many fliers want a stick that will do unlimited vertical and the weight difference between the Lite and Original required the Original to be stronger powered, which itself started the weight escalation and the nimbleness factor gets lost or diminished.
An USL even with a gas engine would come in under ten pounds and this with the extra two servos for the quad wing and firewall and gear mount beefing. And it required only an 8 oz fuel load so was considerably more nimble than the Original.
