RCU Forums - View Single Post - Trying to make engine run backwards
Old 09-03-2003 | 06:56 PM
Sport_Pilot's Avatar
Sport_Pilot
Default Trying to make engine run backwards
If you want to use the engine as in a pusher configuration you don't need to do this, just buy a pusher prop. Else you need to buy a brand that the manufacture has an available reverse crank. Or an engine with a bolt on front housing that you can turn 90 degrees to chang the rotary valve timing.
