RE: troy built/mcculloch 25cc engine stalls
WOW!!!!!!! talk about a boneheaded move, I had the thing plumbed as if it had a bulb but I forgot that bulbs have a check valve in them, I plugged off the return line and the engine idles the same straight down as it dose straight up, thank you for your insight and help. I am so thankful for your input, if you're ever near Prescott Valley and need a cup of coffee just holler. I can't thank you enough!! Keep the shiny side up!!!!
Jeff
