Nose gear placement
If the nose gear is moved back a bit, does it affect the plane in any way? To convert the T-34 to glow, the motor mount is moved back almost 2 inches, which was also where the nose gear attached. I can move the nose gear forward a bit, there is room behind the engine, but not sure how strong a mount I can make for it. Would it still work OK if it was a inch back from the original location? I can attach it with a good strong backing with good clearance from the engine if it will.
