RE: Hitec, how to program down elevator with low throttle
Sounds to me like you have too much engine down thrust. When you cut the power, you lose the down thrust.
If that's it, put some shims under the bottom screws on your motor mount, to tilt the engine up. That may take a couple of different thicknesses to find the right one.
Good luck
Dave Olson
