RCU Forums - View Single Post - Humidity effect on performance?
Old 07-02-2012 | 10:30 AM
av8tor1977's Avatar
av8tor1977
Default RE: Humidity effect on performance?
ORIGINAL: RCVFR
ORIGINAL: karolh
The difference that altitude and humidity makes is no stranger to me as I fly from two fields, one at sea level and the other at approx. 3,000', and the carbs require leaning at the lower altitude and richening at the higher one. Needless to say that at sea level the engine makes about 300 more rpm.
Karol
That's unusual. Full scale take off at richer setting and lean it at altitude.[img][/img]
He's got that backwards. It should be "richen at low altitude and lean at high altitude". Most full size engine manufacturers recommend leaning for take off at density altitudes above 5000 feet. Below that it is full rich for take off and lean out after power reduction and/or upon reaching altitude.
AV8TOR
