RE: Humidity effect on performance?
Not so sure Karol has it backwards as it seems to me that the higher the altitude, the less force on the metering diaphragm to open the metering needle. That means the metering circuit is producing less pressure/flow so the HS needle would need opening to produce the same fuel to air mixture. In this scenario I'm not factoring in any altitude variance in fuel/air mixture however.
