RCU Forums - View Single Post - FUNJET
Thread: FUNJET
Old 07-03-2012 | 07:07 AM
  #1201
moparmyway
Default RE: FUNJET
ORIGINAL: The1User
Hello everyone,
I have a Funjet Ultra and using the ''power pack'' motor, metal motor mount and prop from Multiplex
My question it does anyone know if the plane flies better with the Multiplex Propeller 6x5.5
( http://www3.towerhobbies.com/cgi-bin...?&I=LXBFBP&P=7)
At $7.49 each is there any benefit to using the Multiplex Propeller over a good cheap APC prop?
Joe
I think the plane flies better with the APC E 6x5.5 prop
It will pull a little more power than its "Graupner" counterpart, and give you more thrust.
If max speed is your thing, then a Graupner 6x6 should work great with that setup !!
