RE: Scale Line Models Great Lakes Trainer Build
Dave,
You did a great job restoring yours, she looks great! That is the same scheme I was thinking of, but I also have an old picture that I might go with, still undecided. I was thinking of using Koverall/dope but decided to stick with the simpler iron-on covering. I read your site, sounds like the .40 didn't work out for you, you had to put in a .60? I'm shooting for a .35 equivalent, so I hope it works out.
Sounds like you also had to add some tail weight, was it because of the bigger engine? My motor is a heck of a lot lighter up front, and I should be able to slide the batteries back and forth to balance. I was thinking of putting the rudder and elev servos as far forward as I can, but if it's gonna be nose heavy, I might keep them per plan.
