RE: 1/3 Vickers F.B.19 MKII
Getting some work done on the top wing. Just fitting parts right now. I have made hard wood blocks for the strut attachment points. I drilled a hole through them and the spar passes through. It will all be epoxied together. I'll be cutting out all the center section ribs to make the big window of course. I am using Mick Reeves stainless fittings for the struts and bracing wires that cross inside the window. The wings will plug into the center section.
