RE: 1/12th Scale Edf Concorde
After the wing, while i'm waiting for my dremel's battery to recharge, i pulled out main spar and one of the trailing edge spars to laminate them with fibreglass, while i was doing this, i thought this is perfect time to make nacelle's formers that will pick up the edf units, so made first one, then how about i make sub spars that will act as cradles of the edf units, this way i will make short hard wood edf mounts to bolt on the edf's to and then 2nd set of formers will act as edf cradles also.....
