RCU Forums - View Single Post - Meister Scale Zero - step by step
Old 07-05-2012 | 01:57 AM
mirce
Default RE: Meister Scale Zero - step by step
Hello Doug, yes another Meister Scale... Third will be also Meister Scale - Foke Wulf...
I like Meister Scale models, it's sooooo easy for building, looks great, and modelers talk to fly great. What more you need...
All in all, I enjoyed very much in this building. I will use some my methods, but, at the end, result will be same...
Yesterday I start building right wing half. I will made two parts wing...
I ordered spars, from my friend, and as soon as I get them, started with the building...
At the evening wing look like this...
I made few holes on every ribs, and shaved about 45 grams on this wing half. You can see that some ribs are broken, yes unfortunately that's happen during transport...
Never mind, I will fix it later...
When I was coming back from Top Gun, bringing with myself Zero kit, I must cut wooden wing joiner on two half, because it's so long, that cant be placed in my suitcase. Yesterday I give one half to my friend carpenter, and he will made new wing joiner.
Now I must wait on it to can continue my building progress. Hope I will get it today or tomorrow...
Now, I have question for you guys, does I need gears before putting gear mounts on their place?
Are gear mounts made or good for Siera gears?
On my Meister P 47, I have problem with this parts, I glued gear mounts and latter when I put gears on it I saw that gears wasn't come inside properly in the wing. So, I must soot out gear plates, and gluing it again under other angle.
I don't want to have same problems on this model, so please give me advice, can I put gear plates now, or to wait to get gears?
Regards
Mirce
