RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!)
Have a flap question. I am in the process of setting up my Mustang. I have a Futaba 10cap with a r6014 receiver. I have the flaps set fo full drop with a bit of delayed down elev. programed in when you drop the flaps. I have it set on switch c. A triple level switch. It`s either up or down. I can`t figure out how to get half flaps at the center switch position.
The question is that, how many people with this plane even use half flaps? Do you always land full flaps. I do on my other planes. Also, how much down should i program in. Does this plane nose up bad when applying flaps? Normally i just hold a little down on the stick when landing. Any advice. thanks.
