dbacque- Pretty sure they used the RCM plans as their base- based on the reasoning you describe. Even the horizontal is identically off.
I think some the fiberglass fuse kits Joe put out differed to his wood built plans as well. If I'm not mistaken, I think the bottom of the glass UFO fuse, in front of the wing, does not drop as low as the RCM plans show.
Because of variations like that, I was curious if the BJ profile matched the Bridi glass fuse verses the RCM plans.
Magazine plans would be the original while each iteration after and conversion to kit always dilute the designs.
I will be modifying the BJ kit to build to the RCM plans- including the hardwood motor mounts... Just personal preference to maintain the original outline. I really can't tell you WHY this is so important to me, but I guess it is. The way I get to the outline doesn't bother me...
as much. [8D]
Brian
