RCU Forums - View Single Post - Aileron Servo
Thread: Aileron Servo
Old 09-05-2003 | 12:58 AM
BearcatPilot
Default Aileron Servo
Wow,
Thanks Bill. You know a lot about this kit. It may, however, be too late to install two aileron servos. I have already added the bellcrank mounts but have not done anything else. The bottom part of the center section is still unsheeted to make it easier to drill any holes if necessary. What are the advantages of using two servos aileron control? I guess it would be much easier to set up, with less linkages and only small holes for the wires. For covering, I am using Sig Koverall applied with Stix-it and then I will seal the grain with WB Polyurethane. Is this an OK setup? I have only the covered the rudder and elevators so I can make changes if I need to. Thanks for your help.
