RCU Forums - View Single Post - Webra Bully and Walbro carb help
Old 07-08-2012 | 03:25 AM
Tony Hallo
Default RE: Webra Bully and Walbro carb help
Sounds like a pump problem, is the pulse port lined up?. While choking, you can draw fuel through the carb without the pump, will die once prime is consumedif thepump isn't working. This occured after you replaced thecarb?
