RE: MidWest Sweet-Stick Plans
If you have the plans you should be good. Make a copy you can cut up, or trace the fuse sides. It is just a box, so measure the top and side views to get the formers. Where there is triangle stock cut the corners off. I scratch built my last two Sweet Stick 40's that way. I only needed a couple of tracings, wing ribs, fuse sides, and tail shape. I will measure out the formers and mail them to you if you like.
Good luck.
Scott
