ORIGINAL: boostoman
Alright guys i thought i might make a vid since it would be alot easier to explain to everyone my issues with my engine. they are three main issues im having
1) bubbles coming out of the carb when starting up which is causing issues when starting
2) engine cutting up at full throttle
3) alot of fuel residue and blue smoke coming out of the exhaust. which I think it's due to having too much fuel: oil mix (i''m using 20:1) which i will try to use my normal 32:1 fuel that I use on all other planes to see if it makes a difference.
my setup 11x7 prop. with 4.8v on the ignition
http://www.youtube.com/watch?feature=player_embedded&v=EMfc4_zQLdc<br type=''_moz''/>
Hi Mr. boostman,
You are solve the problems with bubbles in fuel line?
Hi Mr. michaelchow
I have same situation. How I can solve this problems?
Regards
Jimmymugurel
