RE: Help covering scalped trailing edges
Wing nut,
First off, it is referred to as a scalloped trailing edge.
Second, I would start by covering the bottom of the trailing edge, using the heat from the iron to "bend" the covering into the scallops. Trim the excess, and then repeat the process on the topside of the trailing edge.
