RE: miss bud wont run
you can make a tool, if you look at your fly wheel. there are two threaded bolt holes diaginal from each other. What you need to do is get a peice of steel, not to thin as it will bend and drill 2 holes and thread them so you can screw bolts threw the steel bar and into the fly wheel. You also need to drill another hole in the middle of those two bolts and thread it so you can screw a bolt threw the bar and screw it up against the end of the crank. Once you have the two outer screws bolted into the flywheel you tighten the middle bolt thats against the crank and keep tightining until the fly wheel pops of the crank.
hope that helps...if you understand what I mean
