RCU Forums - View Single Post - Goldwing 50cc Pitts Python V3.
Old 07-09-2012 | 05:42 PM
  #91
Mustangman40
Default RE: Goldwing 50cc Pitts Python V3.
ORIGINAL: scale only 4 me
Running a 22-8 on the 55
I'm running a Power Expander Pro so no "Y"s are needed. it has Battery share and regulated 5.0 volts to RX built in and I use the pin switch option. running 2 a123 2300 cells, 2000 mah niMh pack for ignition, Rcxel optikill switch,, no other regulators needed with this set up.
5625 servos for the Ailerons, Running left side chn. 1 right side chn 7 , using the Aileron differential in the Futaba TX, Servo were matched via a Hitec servo programmer. Elevator servos are Programmer matched also. single 7955 for Rudder
CG is where the manual said,, as much of a joke the manual is, it seams to fly well at that point.
glad to be of help, good luck
Thanks again my friend, it always helps when you can talk with someone who has your plane up and running, been there do that type of thing... I will post some more pics soon, the boy robbed my camera batteries for his XBOX controller!
Jimbo
