RCU Forums - View Single Post - Throttle Servo?
Old 07-10-2012 | 05:13 AM
superfli
My Feedback: (42)
Default RE: Throttle Servo?
And the winner is Binding. That was the problem. I didn't realize that slight binding could heat up a servo so quick. I disconnected the throttle spring and the idle screw and replaced the throttle rod. I used end point adjustments to make sure there was no resistence on the servo at both ends. Thanks everyone for your imput. You learn alot on these forums.
Superfli
