RCU Forums - View Single Post - Comp ARF BAE Hawk build thread
Old 07-10-2012 | 05:53 AM
  #784
tucson
Default RE: Comp ARF BAE Hawk build thread
Well it looks like I found the right combination to offset the gear so the doors will close.
I added 1/32 shims to the two outboard gear mount tabs. This has brought the tires low enough to clear the inner doors when retracted.
The problem of toe in still exists. The best I have been able to get is the wheels pointed straight ahead. No toe in. I will settle for this.
Turned out to be a simple fix.
Stan
