RCU Forums - View Single Post - DLE 55 mixture problem
Old 07-10-2012 | 04:00 PM
CK1's Avatar
CK1
My Feedback: (60)
Default RE: DLE 55 mixture problem
It could be a pressure change within the cowl when inverted that is affecting the diaghram vent on the carb .
I would remove the carb diaghram cover and solder a tube to it and run a line from the vent cover to inside the fuselage (away from large sudden pressure changes).
There are several threads on installing the vent tube and line here on RCU.
