Thanks Wayne...
In meantime, I continued to work in parallel on few Zeros parts.
First I made rudder...
I continue working on spar boxes...
On elevator I add balsa leading edges...
Than, first balsa plates on rudder...
...after that on wing...
All boxes are finished...
Elevator leading edge is rough sanded...
I must put a support, because first ply rib was curved. After gluing all top balsa plates I will remove those support...
Small balsa strips was adding for better seating next balsa plate...
Those plates are 15 mm wide...
Than next balsa plates, first on rudder...
...and latter on wing too...
Again...
Finally I removed wing from the working table...
In bottom rudder part I glued next part...
Wing leading edge is more than 1,3 meter long. I must made balsa plate for leading edge from two parts...
Than I glued it in front of the wing...
This model is so huge, but very easy to build. Luckily I find landing gear big enough...
He, he...
Regards
Mirce
