RCU Forums - View Single Post - RX and battery mounting ? and push rods.
Old 07-11-2012 | 08:09 PM
SeamusG's Avatar
SeamusG
Default RE: RX and battery mounting ? and push rods.
Like Jester posted.
A basic (and perhaps unneeded) caution - don't fix the Rx or battery location until you set the CG as the battery is the biggest chunk that can be moved to adjust the CG without adding unnecessary weight.
I've successfully used adhesive backed velcro but first I "painted" the location with alcohol diluted epoxy to give a nice smooth clean surface for the adhesive backing.
