RE: Current drain using YS170CDi?
Hello Thinn,
On my Axiome I consume about 180Mah on the Rx and 86mAh on the CDI battery per flight of 14min.
I use a TP1350mAh for Rx and a TP900mAh for CDI, I usually make 5 flights befeore changing to my second set of bateries.
1100mAh is good for 2 flights for me, as I do not drain the batteries more than 50%, and as you know you can only measure the LiFe when recharging, so not knowing what you have is really scary part in my opinnion.
Regards
