RE: O.S .46LA Head Gasket Help
if you take the point of a exacto blade, and push on the side of the shiney ring surrounding the squish band on the cylinder head it will lift up, i think you dont need anothe rhead gasket, a simple retorqueing after spraying off any goop with some carb cleaner will do the job. the headgasket is aluminum so its very easy to mistake as just part of the head
