RE: Park Zone/Hobbyzonewhat's the difference?
The Parkzone/Hobbyzone tx, if 4ch usually will work with any BNF plane they make. The only exception to that rule I discovered is the TX that comes with the RTF Blade SR. It is a 6 channel radio with built in programming explicit to the Blade SR, and while it does work with the other helis, the controls are all wrong for them. <div>
</div><div>An example is the UM-t28 RTF TX can be used with the PZ T-28 BNF. Note its the 4 channel radios, that will work, the 3 channel ones do not. </div>
