ORIGINAL: PAK26499 Hello. I have a Futaba 4YF 2.4 GHz FHSS radio with the R2004GF receiver. I would like to install it in a Duraplane I have. The duraplane has an aluminum tailboom. Does anyone know if the tail boom would cause any interference with the 2.4 GHz system? I currently use a FM radio system and it works just fine but would still like to switch if I knew it would be just as reliable. Thanks in advance........
Install ensuring RXantenna tips are not parallel nor closeto the boom,
range test as always, then go fly.
Not same brand, but pictures in following might assist:
Optima Transceiver (RX) - Installation RX & BODA Antenna FAQ,
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
