RE: Webra Bully and Walbro carb help
Nope not yet. I have been busy for the last 2 weeks moving a 50 employee modern machine shop to a new location and it has been intense! My ***** is dragging but I still like to chat on the RC forums for a bit of R&R in the evenings.
I wanted to ask you what ignition setup you are using. If you are running the original module that is a true magic act since they are over 30 years old in technology. You will definitely need to upgrade to a modern ignition or you will never get your "Bully" to run right.
You need 2 things.
A new ignition setup and a new carburetor. She will rock with this double combination/upgrade.
No sense in a new carb if you do not upgrade the ignition.
Let me know what you want to do. It is an act of futility to install a new carb without the new ignition.
SPEEDY
