RCU Forums - View Single Post - Old Soviet Union 10cc engine
Old 07-13-2012 | 07:13 PM
  #117
earlwb's Avatar
earlwb
Default RE: Old Soviet Union 10cc engine
Your fuel looks to be reasonable. Unless the methanol absorbed too much moisture and is contaminated. But other than that I would suspect the glow plug is bad. I have had them do that before and when I put on a new plug, it started working correctly.
I suppose if you ran the engine way too rich it would drown out the glow plug too. So in that case maybe a little more lean is needed. You want to break in the engine running on the rich side, but not so rich as it drowns out the glow plug.
