Technique for changing pushrod connections
Is there a technique to changing the pushrods where they connect to the control surface arm? It looks like I would need to "bend" the plastic horn to remove the pushrod to the point that it might loosen the attachment to the rudder/elevator/etc. Is there a trick I need to know before I try this?
