RE: DBC/DBU2 problems, need advice(fixed)
The three wire tests good with my meter.
I have reheated one solder joint on the board that looked bad with no luck. I am going over the others with a 10x loup. I have soldered miles of stuff so I know that a cold joint is a bad connection.
I'm going to switch the servo connections after supper.
