RCU Forums - View Single Post - Gp Waco Bipe 120...how wide?
Old 07-14-2012 | 04:13 PM
skypup50
Default RE: Gp Waco Bipe 120...how wide?
ORIGINAL: althepal88
My cowl is about 9 1/2 inches wide; fine if you have padded seats and don't get a prop in your armpit. From the top of the cabane struts to the ground in about 19 1/2 inches, and I am using Skylight 4'' wheels inside the pants. My plane goes to the field assembled in the back of my shortbed/covered pickup. If you use the carrying/assembly unit, you will have to add to the height. Can't you put her at an angle?
I really appreciate your help. After a lot of thought I decided to try the DLE 20 in a Hangar 9 pulse 120. Fewer transportation and set up problems. Thanks again. I really love the Waco.
