RCU Forums - View Single Post - Technique for changing pushrod connections
Old 07-14-2012 | 06:28 PM
BIGMIG
Default RE: Technique for changing pushrod connections
ORIGINAL: 70x7
The horns have about 5 holes in them. The plane came with the rods inserted into the outermost hole (giving the least amount of control). I am wanting to move them into holes closer to the control surface (giving more reaction). The bends in the rods are for adjustments in trim.
If the control rod is allready on the outermost hole on the servo control horn,it is allready giving the maximum throw from the servo.............
To increase throw you need to move it in on the horn on the other end.
BIGMIG
